Chassis Lubrication 2008
Old Jun 9, 2014 | 11:16 PM
Wampa's Avatar
Wampa
OP, I Just Had this issue after installing z51 sway bars. Mine was simply a matter of tightening end links to torque. They are 53 ft/lbs; which I didn't think was all that much and didn't use a tq wrench when installing. Started making noise while mountain carving 2 weeks after installed. got very bad--every time suspension articulated. Torqued them with tq wrench when returned, Easy to access with wheels off. Immediately fixed and No problems for a month now. Try that before buying anything. Good luck!
Old Jun 10, 2014 | 08:37 PM
TX-Techman's Avatar
TX-Techman
Thanks, I found nothing worn at all so this makes sense. I will put her back on the lift this weekend and see what I find. I know it can't be anything too serious, I just haven't had a chance to dig into it much. I will post back once I have a chance to check.
