Short Throw Shifter & Boot
Old Jun 14, 2014 | 12:15 PM
LD85's Avatar
LD85
Default Short Throw Shifter & Boot
When I installed my Short Throw Shifter, the shift boot hole was too large for the new shift rod since it is from a C5.
All of the posts on CF suggested a new boot or ,,putting a tie wrap around the boot and cinching it to the new shift rod before installation.
What I did was use a rubber grommet, like the kind from Home Depot or Autozone etc that you use when you drill a hole in into a sheet metal or firewall and you use the grommet to protect the wires that you shove thru the hole. Total cost is less than $1.00
I measured the I.D. of the boot hole, and then measured the OD of the Shift Rod.
Slip the Grommet over the shift rod and push the boot into the slot in the center of the Grommet, the cool part is that it is rubber so no vibrating or noise issues.
Grommet pic
Pic of the grommet on my shifter
Old Jun 14, 2014 | 12:21 PM
truckplay's Avatar
truckplay
very creative, good for you.
Old Jun 14, 2014 | 02:55 PM
LD85's Avatar
LD85
Thanks TP, its easy to spend big $$$ but I like it when a cheap solution fits the bill!
I can machine a Black Delrin piece to be exact and do the job , but the grommet does the deal
To Short Throw Shifter & Boot
