'06 knock sensor location
Old Jun 14, 2014 | 12:53 PM
JShocik's Avatar
JShocik
Default '06 knock sensor location
I have a CEL on for what turns out to be knock sensor #2. The service advisor tells me it's located under the intake manifold. One of the techs said it's under the motor, with the exhaust manifold having to be moved to get to it. Doing a quick search here, some members are saying it's just above the starter. I need this sensor changed, but I want to know where it is. Who's right?? Thanks.
Old Jun 14, 2014 | 04:04 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
There is one on each side of the block. The exhaust manifolds would need to come off to get to them.
Old Jun 14, 2014 | 04:22 PM
shawnaj7731's Avatar
shawnaj7731
if you have headers its a 5min job.
Old Jun 15, 2014 | 01:56 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Should be drivers side front left side of block plug and play.I think it is black the plug in part.
Old Jun 15, 2014 | 09:04 AM
tennblkc6's Avatar
tennblkc6
I know for a fact there is one above the starter on ls2. you will need to loosen the starter to get to it.
To '06 knock sensor location
