noise and grinding
Old Jun 16, 2014 | 10:58 AM
fastls3's Avatar
fastls3
Default noise and grinding
Car is a 2007 Manual
Monster level 2 clutch
Mild cam 423whp 407wtq
wide body
Mgw shifter
A few weeks back I took my car to the drag strip.
Ended up having the slave go bad. Had the car towed to a friends shop and when I picked it up after a new gm slave and tick speed bleeder install I had a grind on a 3rd gear downshift and a slight whine. Prior to all of this I had a occasional grind while putting it in reverse. Sent car back to shop and had the trans fluid changed to royal purple scynchromesh in hopes that would help and had clutch bled. Now there is a grind on first gear down shift also. Changed fluid again and bled system with all the same issues remaining. Just trying to figure out my next step. Thank you
