Fit and Compatibility
Old Jun 17, 2014 | 10:42 AM
kimdjay's Avatar
kimdjay
Default Fit and Compatibility
I'm looking at different options for power increases. duh, like anyone else.
I have an 06 with the std LS2. I have headers and cats and that good stuff. If I were to swap heads to L92 heads or go with an LS3 engine altogether, would I also need new headers. or are the exhaust port configurations pretty similar between LS2 and LS3 applications?
thanks for any input.
Old Jun 19, 2014 | 03:54 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
I dont believe the headers will work on both.....an ls3 swap isn't worth it for the 35hp difference. What hp do you want to be at? Heads/cam or fi would be a WAY better option.
Old Jun 19, 2014 | 04:06 PM
400ci94mm's Avatar
400ci94mm
Head/cam kit with appropriate cam upgrade to match. 100 HP increase or close.
If you need more....put a small 100 shot of spray.
Those two will equal about 600 RWHP.....then you'll need some transmission upgrades.
Old Jun 21, 2014 | 08:31 AM
kimdjay's Avatar
kimdjay
I guess that brings me back to my question. if I have different heads, other than the LS2 design.. Say i go with LS3 heads, are the exhaust ports the same so that I don't have to change out the exhaust too? I know that Intake port shape/size are different as well as the intake manifolds. I never see much info about exhaust port design across different heads.
Old Jun 21, 2014 | 09:23 AM
timd38's Avatar
timd38
I went with a LS3 top along with a cam, FAST intake, CNC heads, etc and picked up 100 at the wheels. I used my LS2 headers with no issues. I would contact the headers supplier to confirm becasue the LS3 exhaust ports are slightly bigger.
To Fit and Compatibility
