Is my engine oast?
Old Jun 17, 2014 | 08:38 PM
Dave Cooper's Avatar
Dave Cooper
Default Is my engine oast?
At about 13,000 miles, the oil pump on my 2010 Coupe decided to die. The symptoms were pretty obvious: chuga-chuga sound from the engine, zero oil pressure, no power, ticking lifters. I instantly turned off the engine and had it towed to the dealer for repair under warranty. Although distressed that stuff happens, I just left it to the service people to fix it.
They noted some scoring in the bore but otherwise ok and replaced the oil pump.
Now, 2000 miles later I discover that they DID NOT REPLACE THE OIL AND FILTER but just topped off the oil!!! I am just heartbroken that this could have inflicted permanent damage to the engine. Is it possible to replace an oil pump without draining the oil? Am I being overanxious? Suggestions please.
Old Jun 17, 2014 | 10:00 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
I think the concern would be how much metal shavings went throughout the motor?
Old Jun 18, 2014 | 08:19 AM
MARSC6's Avatar
MARSC6
Are you sure the filter and oil wasn't changed?
I'm losing all faith in these dealerships.
Old Jun 18, 2014 | 10:23 AM
haljensen's Avatar
haljensen
How did they drop the pan to get to the pump without draining the oil?
Or did they drain it into a container and reuse it?
Old Jun 18, 2014 | 10:46 AM
Redrocket1045's Avatar
Redrocket1045
No need to drop the oil pan. All LS engines oil pumps are accessible by removing the front timing chain cover.
Old Jun 18, 2014 | 10:50 AM
Tonylmiller's Avatar
Tonylmiller
I think you need another engine. That one could be oast.
Seriously, though, I would be very unhappy with the situation. If it was under warranty, in some ways it would have been better to drive it until it seized.
Old Jun 18, 2014 | 06:35 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Dave Cooper,
My deepest apologies to read about this situation. I certainly understand your frustration and would like to assist. When you're able, please message me privately so we can discuss the matter further. I look forward to hearing from you.
William R.
Chevrolet Customer Care
Old Jun 18, 2014 | 06:58 PM
Bill Dearborn's Avatar
Bill Dearborn
Are you sure they didn't replace the engine oil? The FSM procedure for replacing the oil pump when there is no oil pressure is to pull the oil pan as the oil pump, screen and crankshaft oil deflector all have to be removed/cleaned/replaced. I doubt they would have just replaced the oil pump alone when the procedure clearly defines what they have to do. Check the repair bill to see what operations were done.
Bill
Old Jun 18, 2014 | 08:08 PM
Rusler John's Avatar
Rusler John
I'm curious as to how they noted scoring in the bore without any disassembly of the engine ( oil pan, heads ). I guess they could have used a bore scope down the plug hole.
Old Jun 19, 2014 | 12:10 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Bill
I doubt that any tech would not replace the oil & filter as the oil pump has to be primed too. If there was damage to the bearings you would see a drop in oil pressure.
My concern would be how much and how bad was the scoring
Old Jun 19, 2014 | 05:41 PM
blkbrd69's Avatar
blkbrd69
First thing I would do is an oil analysis.
http://www.blackstone-labs.com/
That will tell you alot, let the Blackstone people know your situation. They can tell you if damage was done. If you change your oil, keep your filter and or cut it open for more evidence.
A lousy tech can and may replace the pump without lowering the pan or changing the oil.
Most are great guys and would not do this, but service writers & managers can and do pressure techs.
Old Jun 23, 2014 | 04:47 PM
Dave Cooper
Thanks for the info. I'll grab the oil filter & have it analyzed
Old Jun 23, 2014 | 06:24 PM
blkbrd69's Avatar
blkbrd69
Good writeup on how to sample.
http://www.blackstone-labs.com/gas-sampling.php
To Is my engine oast?
