check engine light /reduced engine power
Old Jun 22, 2014 | 01:07 AM
BOBSZ857's Avatar
BOBSZ857
Default check engine light /reduced engine power
I took car out yesterday and went for a ride and all was fine. Stopped for a while and when I started the car and was heading home, I got a check engine light and a reduced engine power message in the DIC. Battery voltage seemed a little erratic and car stalled out a few times. The car is an 05 M6 Vert and has always been hooked up to a battery tender when stored. The battery was replaced when I picked up the car in Sept. of 2012. Does this sound like a bad battery or is it more involved? As always, thanks for your input.
Old Jun 22, 2014 | 08:02 AM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I'd suspect the battery first and get it load tested.
Old Jun 22, 2014 | 09:09 AM
tennblkc6's Avatar
tennblkc6
you stated that it's anyways on a battery tender...have you ever pulled the caps and checked the water level?
Old Jun 22, 2014 | 10:02 AM
BOBSZ857's Avatar
BOBSZ857
Will check water level and get it load tested today. Hopefully that will resolve this.
To check engine light /reduced engine power
