Proper technique for adding Torco to tank
Old Jun 23, 2014 | 02:04 PM
Red Sleeper's Avatar
Red Sleeper
Default Proper technique for adding Torco to tank
I'm not sure if I'm getting a good mix of my fuel additive (Torco) when I pour it in my tank. Since there are basically two tanks is it possible to get a bad mix? So if I have about 5-gallons in the tank can I just add it in and expect it to get mixed properly?
Old Jun 23, 2014 | 06:43 PM
haljensen's Avatar
haljensen
Best way is to start with a 1/4 tank, then add the appropriate amount of Torco to get the Octane you want. It'll all be in one tank and should mix correctly.
Old Jun 23, 2014 | 08:51 PM
Bill Dearborn's Avatar
Bill Dearborn
Mix it into the gas before putting the gas in the tank. Get yourself some VP Fuel containers along with the large VP funnel and add the fuel to the car that way.
Bill
Old Jun 23, 2014 | 09:42 PM
Red Sleeper
This sounds good to me.
I just didn't want my Torco to be in one tank and use from the other.
Thanks!
Old Jun 23, 2014 | 09:45 PM
Red Sleeper
Bill
Thanks, but this is not going to be possible. When I go to the strip my car is full of drag radials, jack, tools, laptop, chair and a wife. Pretty much out of room.
Thanks again
Old Jun 24, 2014 | 10:49 AM
Dano523's Avatar
Dano523
Drivers side fuel tank is what you are filling, then once its full, the fuel will slosh over through the transfer tube to full up the passengers tank.
The fuel is first pulled out of the passenger tank to be used (until the dash fuel gauge gets to about half full), and once it's empty, then the fuel is used out of the drivers tank.
So on that note, if you keep the fuel under 1/2 full on the gauge (just fuel in the drivers side tank to mix in that tank alone), then the fuel will only be in the drivers side tank, and the tank being used alone.
As for additives, it's only as good as the fuel you are using as the base, and I mention this since the fuel you are using may be littered with ethanol. If such is the case, then may be better of just running the tanks near empty, and hitting up a Avgas pump or race fuel pump to top the tanks off before heading to the strip instead.
Old Jun 24, 2014 | 11:46 AM
Red Sleeper
Thanks for the insight on how the tanks empty. That's what I really needed to know. With that knowledge I should be able to control my octane lever better than I had been.
Torco is the real deal IMO and has worked great for me. However, in the past I poured in 32oz and then filled the tank up. When I got to the track I usually had more gas in the tank than I wanted for racing nor did I raise my octane level as much as I needed.
Gas is 93 octane here with some unknown amount of ethanol in it. I can buy race gas 101 octane near the track but you cannot pump it directly into your car which makes it a hassle if you don't want to carry a gas can around.
Getting the right mix is important on a boosted car. That's why I'm so concerned about getting a good mix.
Thanks!
Old Jun 24, 2014 | 01:07 PM
gbrtng's Avatar
gbrtng
At the point the RH tank is empty, what keeps fuel from sloshing from the LH tank to the RH one? How does the fuel pump(s) deal with fuel in one or both tanks?
Glenn
Old Jun 24, 2014 | 03:15 PM
Red Sleeper
Glenn
I found this - may help
http://www.hessh.de/Corvette/FuelTankSystem.pdf
Old Jun 24, 2014 | 04:54 PM
Dano523's Avatar
Dano523
Glenn
Slosh cross over tube is at the top of the tanks, and if you corner hard enough to slosh the fuel back over to the empty passenger tank from the drivers tank , then the passenger tank pump will pump it right back to the driver tank to be used.
Old Jun 24, 2014 | 06:42 PM
haljensen's Avatar
haljensen
We are assuming that both tanks are the same capacity?
Have to remember that EMPTY on the gauge still leaves aprx. 2 gallons in the tank. Does that mean the 1/2 tank reading means 8 gallons in the drivers side tank OR does it mean 10 gallons with the "hidden" reserve?
Old Jun 24, 2014 | 10:10 PM
Red Sleeper
After studying the drawing and operation on this link: http://www.hessh.de/Corvette/FuelTankSystem.pdf
I think the gas is constantly being circulated between both tanks while the fuel pump is running. Which means you can add an additive at any fuel level and it would eventually get mixed up.
Hopefully if I'm wrong someone will let me know.
Old Jun 25, 2014 | 09:24 AM
haljensen's Avatar
haljensen
The link clearly states that the right tank is emptied then the left tank is used as supply. Nowhere does it state that fuel is transferred back and forth between left and right tanks.
Old Jun 25, 2014 | 10:42 AM
Red Sleeper
Well, it says that excess fuel pressure is transferred back to the tank therefore if fuel is flowing (circulating) the venturi pump is operating and pumping gas to the left tank. I theorized that if the left tank is already full it just drains back into the right tank - continually circulating.
Quote:
The turbine pump creates more pressure and more fuel
flow than the engine needs. Excess pressure and excess fuel is allowed to bleed back into the left tank by the primary fuel
pressure regulator (V) within the tank.
Quote:
TIP: The pressure regulator is in the fuel tank, not on the fuel rail on the engine. This type of fuel system is called
returnless, or demand. This means that excess fuel is diverted before it leaves the tank, instead of passing through the
fuel rail before being diverted. The result is that hot fuel is not constantly returning from the engine compartment, so the
fuel in the tank stays cooler, improving evaporative emissions.
Quote:
Some of the pressurized fuel is directed to a venturi pump in the left tank. This pump uses fuel flow to siphon fuel from the
main tank into the reservoir, to keep the turbine pump supplied with fuel at all times. As the left tank fuel level drops, the
venturi pump scavenges all of the remaining fuel into the reservoir, regardless of the vehicle’s attitude.
Old Jun 25, 2014 | 11:37 AM
Unreal's Avatar
Unreal
Fuel pump is in drivers side tank, siphon pump draws from passenger to keep drivers side full. So when you are full, both tanks have ~8 gallons in them. As you drive it pulls from the drivers and keeps refilling it from the passenger until that is empty, then there is nothing to pull and you are just running off drivers side. When you fill from dead empty it fills drivers until it gets to the crossover then just spills over into passenger side. If you added torco to a full tank there is a chance the drivers side could be high concentration for awhile until it has time to mix. I wouldn't add it to a full car if possible.
Old Jun 25, 2014 | 11:58 AM
Red Sleeper
Agreed
Old Jun 25, 2014 | 06:42 PM
haljensen's Avatar
haljensen
Correct, there is no transfer "back and forth". When the passenger side empties fuel is taken from the drivers side.
We still don't know if the tanks are equal volume.
Old Jun 25, 2014 | 08:32 PM
Unreal's Avatar
Unreal
They are approximately equal volume. The pump/etc displaces more room in the drivers tank, but they are within 1/2 gallon or so.
Fuel is always taken from the drivers side, just the passenger side refills the drivers until it is empty.
To Proper technique for adding Torco to tank
