Coupe carpet removal question
Old Jun 25, 2014 | 08:33 AM
Peter_Reinhard's Avatar
Peter_Reinhard
Default Coupe carpet removal question
Hello
I'm finally doing the heat insulation kit along with some sound deadening (dynamat, MLV) on my 08 coupe. By following multiple posts and directions with the kit I'm almost there; seats out, sills off, passenger carpet out, far rear panel out. But looking at the front of the rear carpet (if that makes any sense), it looks like I might need to remove the coupe lid shocks to remove the speaker covers. One post said you don't need to, and another said you do. I'm thinking it will be a pain to work around if I have to cut a stick to hold the rear lid open. I could see knocking the stick by accident and getting a sudden headache. But it looks tight. Anyway, any advice is appreciated. Do I need to remove the rear speaker panels too?
Thanks.
Old Jun 25, 2014 | 09:05 PM
black.z51.c6's Avatar
black.z51.c6
you do I used a shovel to hold up the trunk.
Old Jun 25, 2014 | 09:12 PM
black.z51.c6
and knocked the stick out and hit my head or back... I don't remember
Old Jun 25, 2014 | 09:53 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
I did mine in the garage and used a piece of twine from the lock assembly to a nail I stuck in the ceiling. No headache here.
Old Jun 26, 2014 | 01:53 AM
HOXXOH's Avatar
HOXXOH
I never removed the speaker panels. It's just a matter of tucking the carpet back in when you're done. I think I used a putty knife to push it in.
Old Jun 26, 2014 | 10:25 AM
deadsexyii's Avatar
deadsexyii
The carpet doesn't stick up that far behind the panels, so if you're only doing insulation I think you could get away with not removing them. I pulled mine, but I was also doing an audio install in addition to the insulation.
Old Jun 26, 2014 | 12:45 PM
Peter_Reinhard
Thanks for the replies. I'll try it without removing any more plastic, and if I need to, I'll use a rope and tie it open to the ceiling of the barn. Good idea. Thanks again.
Old Jun 28, 2014 | 01:09 PM
carpe dm's Avatar
carpe dm
Old Jun 28, 2014 | 09:08 PM
ls1121's Avatar
ls1121
I removed mine and installed the sound deadening material back there also. I had everything out so I did not want to go half way with the job.
To Coupe carpet removal question
