trick performance clutch master cylinder
It starts about 50%, my other cars start to engage at 25-30% which I prefer. I removed the spring, much better feel but I'd still like it to engage lower. I have trouble shifting 1st to 2nd smoothly, consistently.
http://forums.corvetteforum.com/c6-t...r-cyl-kit.html
http://forums.corvetteforum.com/c6-t...tch-pedal.html
The Tick master cylinder has a wider body ID, while means that it flows more fluid for the same amount of pedal stroke as the factory unit. Due to this, when the Tick is adjusted correctly so it does not press the clutch in farther than needed, the first 3/4" to 1" of pushing the pedal down from all the way up is doing nothing (become free play before the plunger starts to move fluid).
Simply, your going to lower the engagement/disengagement of the clutch about 3/4" to 1" lower on the pedal than it is now.
As for pulling the clutch return spring, jury is still out on that one, and better to leave it in play.
