Tune after tb install?
Old Jun 27, 2014 | 02:10 AM
C5-1's Avatar
C5-1
Default Tune after tb install?
Do I need a tune after a stock throttle body install. I got the P02138 code...traced the issue to a bad tb sensor.
Is it just plug and play?
Old Jun 27, 2014 | 08:40 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
No tune required if that is all you are changing. Disconnect the battery before starting your work. You may still need to manually clear the code after so don't get worried if the light is still on.
Old Jun 27, 2014 | 11:14 AM
C5-1's Avatar
C5-1
Thanks for the info Sevinn
To Tune after tb install?
