Driver door hard to open
Old Jun 28, 2014 | 08:25 AM
stein3282's Avatar
stein3282
Default Driver door hard to open
My 06 with 66000 miles drivers door is hard to open. I have to just keep pressing the button until it finally opens. Sometimes after a minute or so I give up and open it through the hatch with the wire.
Do I need to replace the switch? Or is there any tricks to fixing it etc...
Old Jun 28, 2014 | 09:10 AM
chevyguy3's Avatar
chevyguy3
You an replace it easily, just 2 screws. But it is also usually pretty easy to make your factory switch work a lot better on your own. Just open it up, use some fine sandpaper to lightly clean the corrosion off of the contacts (the corrosion will be obvious), smear some dielectric grease on it and put it back together. Five minute job per side. There was a good writeup somewhere on the site before with pictures, but if you just take the switch out you'll understand what needs to be done.
Old Jun 28, 2014 | 04:40 PM
2StrikeHtr's Avatar
2StrikeHtr
http://forums.corvetteforum.com/c6-z...n-minutes.html
Old Jun 28, 2014 | 05:17 PM
cclive's Avatar
cclive
Because you live in a humid place, the door switch (rubber pad) likely has corrosion. Cleaning it yourself is better than a new one because you can also coat the contacts with a corrosion inhibitor to stop it from happening again. As stated above, you can open it up and do it yourself in a few minutes, then end up with a better switch than a new one. Be careful not to let the wiring harness fall back into the door...this can make the process MUCH longer. To test the switch, you can switch driver and passenger sides and test. They are both the same part.
Old Jun 28, 2014 | 08:28 PM
stein3282's Avatar
stein3282
Thanks everyone. I'll give it a try.
To Driver door hard to open
