Alignment specs
http://www.pfadtracing.com/docs/camb...t-settings.pdf
Notice that there is no "range". Take your car someplace that knows what they are doing with alignments and talk to the tech and explain that you want your car set up "exactly" to these specs, no "range" and exactly the same on each side.
Thats exactly what I did one week ago.Also it doesnt hurt to try and find someone with a newer alignment machine thats also what I did.
As for getting that sensor read out with the alignment print out on the same page, not sure if there are any alignment machines that will pull the steering wheel sensor read out at the same time as the alignment, so I ask to see the read out on both the alignment machine and the tech 2 at the same time before the do the print out (toes reading O as well as the tech 2 steering wheel sensor reading 0 at the same time). This keep them from guessing if the steering wheel is straight when the car is aligned/having to bring the car back to have the steering wheel straighten instead.
Keep in mind the "right" specs are dependent on how you drive. A parade car will be much different than a car used to go canyon carving. A daily driver will be different than those two.
