Service active handling ABS light
Old Jul 17, 2014 | 08:29 PM
Billyac's Avatar
Billyac
Default Service active handling ABS light
On my C6 2005 Service active handling system light came on Traction control works fine and brakes worked five I'm thinking it's some kind of bug can anybody tell me what the problem is and what I can do
Old Jul 17, 2014 | 10:54 PM
RicK T's Avatar
RicK T
Don't want to scare you but you need to take this as a potentially serious safety problem.
Since we don't know anything about your car and we don't know what you know about your car's history, I suggest you acquaint yourself with these 2 discussions (from the Stickies at the top of this Forum) then go to your dealer and get a history printout on your car to find out what has or has not been done. Then you can make informed inquiries, ask questions here and make appropriate decisions.
http://forums.corvetteforum.com/c6-t...er-action.html
http://forums.corvetteforum.com/c6-t...-recalled.html
Old Jul 18, 2014 | 12:32 PM
psp6158's Avatar
psp6158
I agree with Rick,get codes checked, my issue was the ECBM...
Old Jul 19, 2014 | 03:49 PM
Billyac's Avatar
Billyac
Okay great I am going to try and work on it Does anyone know what will it cost If it's a minor Problem And what is the worst case scenario
Old Jul 19, 2014 | 07:38 PM
Bill Dearborn's Avatar
Bill Dearborn
No way to know. Problems can be solved by anything from a simple wiring fix to replacement of a high cost part.
Get the codes read by somebody who has a scanner that can read ABS codes and report them back here. The Service Message is displayed when there is a code affecting that particular function. It sounds like you have a solid message that doesn't come and go. AH is totally inactive until the message disappears so you don't have to worry about a safety issue while it is displayed other than not having AH.
Failures with the steering sensor can cause AH to shut down while keeping ABS and TC active. I do this when I take my car to the track. I pull the connector to the steering sensor so the system can't use AH to slow my car to 55 mph when I use tires without tire pressure sensors.
Bill
Old Jul 19, 2014 | 07:44 PM
Billyac's Avatar
Billyac
It used to come and go now it is on Traction control seems to work fine And ABS brakes seem to work fine also But that is a great idea to Get to codes and post him on a form Will a place like AutoZone Have a scanner
Old Jul 19, 2014 | 07:46 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
is that ICBM or BCM? A New BCM fixed my problem.
Old Jul 19, 2014 | 09:14 PM
psp6158's Avatar
psp6158
EBCM electronic brake control module... Common issue for GM, not just Vettes. $1500.00. Typo,sorry
Old Jul 20, 2014 | 01:05 AM
JohnToner's Avatar
JohnToner
Without OBD codes, its all a WAG, Had that DIC msg on my Escalade, checked code and it reported Throttle Position Indicator. Got an AC Delco replacement from Amazon and it was just a half hour job I did in my driveway. But you need the codes. Buy a reader from AZ. They aren't expensive.
Old Jul 20, 2014 | 02:05 AM
Billyac's Avatar
Billyac
So best case scenario is a loose wire in the telescopic steering well worst-case scenario ebcm How much Would it costs at a dealer To do both
Old Jul 20, 2014 | 04:30 AM
Billyac's Avatar
Billyac
Should I take the Fuse out of the ABS???
Old Jul 22, 2014 | 03:25 PM
Billyac's Avatar
Billyac
Just got back from my mechanic brown the codes said that it is a right rear hub bearing Does this sound right to anyone
To Service active handling ABS light
