Advice on LS2 Stroker Build
Old Jul 18, 2014 | 07:27 AM
BrownPants209's Avatar
BrownPants209
Default Advice on LS2 Stroker Build
I dropped a valve and since i needed to tear it apart, i figured i might as well stroke it. Thankfully there was very minimal cylinder wall damage. I'm just looking for some advice in the direction I should take this. I would like to see somewhere between 550-600 at the wheels. The trick is to keep it N/A..
I have the G6X3 cam with LG's 1-7/8 s/p catless exhaust. In the very near future (once i get the car running) I'll pick up the Fast 102 & NW 102 TB. I'm still not decided on the intake though..
I have seen great things said about TF's 225 heads, and that the 235's are a little to big for the LS2. But I'm curious that if I increase it to a 4" stroke (and bore it a little if the pros outweigh the cons) that the head would be used to max efficiency? Any insight would be appreciated with that!
I'm not entirely sure about how solid the cylinder sleeves are when (if) you try to bore them out. The shop i dropped the block off said that the gains of going .010" - .030" over wont be noticible enough on the street to compensate for a loss of cylinder sleeve strength.
Another thing is a piston head that works with the TF 225 or 235 to raise the compression ratio. What head should I be leaning towards if the 225 is the best head for this setup and if the 235 head is best for this setup?
Also, going to need a new valvetrain. Rockers, springs, valves, lifters, ect... Any ideas on that?
Old Jul 18, 2014 | 10:37 PM
Jim_H's Avatar
Jim_H
In addition to stroking you might also consider having the cylinders re-sleeved to a bigger bore, it will help to hit those kind of RWHP numbers. This would also allow you to run LS7 style heads.
Old Jul 19, 2014 | 08:35 AM
07_C6_WPB's Avatar
07_C6_WPB
I have an LS2 also, I am midway through a turbo build. If I would have stayed NA I would have bought a Texas Speed LS3 bored/stroked shortblock or a LS7.
To Advice on LS2 Stroker Build
