Has anyone done this to their LS3? I am looking to get a bump in power but still need to pass smog/emissions. Any feedback would be greatly appreciated?
...LS9 was done on the Camaro forum= 13 rwhp..LS7 would be about the same. You probably could get about 10-12 rwhp from the SLP 1.85 rocker arms instead of changing/doing the cam but would need to change the valve springs.
Too much work for minimal return. If you have to have a cam, then go custom. With a custom you can have the cake and eat it too.
Btw, you have to change the cam sprocket too since both are 3 bolt type unlike the 1 bolt in the ls3.
Not even worth the hassle and cost for minimal gains! Go with a custom grind, get 40HP, maybe get the heads ported and polished while you're at it and get another 15-20 HP. Be sure to do the dual rocker springs while your swapping out the cam.
if you are going to do the LS9 cam I would look into GMPP 19300535..probably not 40 RWHP but with a tune 30 seems possible. I have been looking at this "combo" also.
That combo is an LS7 cam with CNC ported LS3 heads. For all of that, you get a whoppin' 40 hp increase? Get in touch with Pat G and get him to spec you a cam that will pass emissions. He's done a jillion of them.
