Turn One Power Steering Pump
Old Jul 24, 2014 | 12:02 PM
timd38's Avatar
timd38
Default Turn One Power Steering Pump
I just ordered a Turn One Power Steering pump. Does anyone know about how long it take to change the PS pump?
Thanks!
Old Jul 24, 2014 | 04:05 PM
timd38's Avatar
timd38
I think I will outsource it.
Old Jul 25, 2014 | 07:52 PM
CHJ In Virginia's Avatar
CHJ In Virginia
It's not a really tough job. If you are reasonally proficient with tools, you can do the job and flush the system in about 4 hours. Do a search, there have been several DIY posts on this swap. Check your hoses carefully for any leaks. It is a whole lot easier to replace them if necessary with the pump out. You DO NOT have to move the ABS module like the factory manual specifies. Another BIG time saver is the Turn One billet pulley. It has slots in it allowing a very easy install. Just use a pry bar on the old plastic pulley breaking it so you can access the bolts mounting the pump.
To Turn One Power Steering Pump
