seat memory modules
Old Jul 26, 2014 | 10:18 AM
kctecser's Avatar
kctecser
Default seat memory modules
Are the seat modules different between the drivers and passengers side?
I changed the drivers module and now the steering column doesn't adjust. I have voltage coming from the column switch, and if I jump the motor directly it works. Seems like there is no output from the controller.
Is it possible it's a passenger side controller,and it doesn't have the column circuit?
Any suggestions would be appreciated.
thanks
Guy
Old Jul 26, 2014 | 03:21 PM
VET4LES's Avatar
VET4LES
Try pulling out these connectors from under the drivers seat and zip tying them. It worked for me and many others.
Old Jul 26, 2014 | 04:14 PM
cclive's Avatar
cclive
It's far more likely to be the connectors than anything else.
Old Jul 28, 2014 | 08:45 PM
kctecser's Avatar
kctecser
the module needed to be set up again.
plugged in the tech II and went to module setup
everything now works
To seat memory modules
