Throw out bearing install
Old Jul 26, 2014 | 06:17 PM
BMWTECH's Avatar
BMWTECH
Cruising
Default Throw out bearing install
Hey everyone, I just installed a new clutch and throw out bearing in my 07 z06. With the line disconnected to the slave the clutch pedal is stiff and will not move, I had some trouble getting the line to reconnect, the oring had enlarged slightly and would not let the line snap all the way in. I have the line installed now but the clutch pedal is still rock had even with the bleeder open. Anyone had a similar issue? the car was apart for awhile.
Old Jul 26, 2014 | 11:36 PM
Dano523's Avatar
Dano523
The disconnect between the master and slave cylinder lines is not seated/clipped all the way in correctly, and the valve between the two in the connector is still closed.
Old Jul 27, 2014 | 09:14 AM
BMWTECH's Avatar
BMWTECH
Cruising
Thanks! I will try to again, this part is really being difficult!
Old Jul 27, 2014 | 10:10 AM
dev1360's Avatar
dev1360
That connection is really hard to push in. It took me a while and some creative thinking. Put the clip inside the female end, and when it snaps, you know you're on.
Old Jul 28, 2014 | 06:59 PM
sliderbkt's Avatar
sliderbkt
When I changed mine out I could never get the two to fit together. I ended up swapping parts off of the old slave to get them to fit. I don't remember what parts I swapped, sorry. But it was pretty quick and easy once I figured it out.
Old Jul 30, 2014 | 06:02 PM
BMWTECH's Avatar
BMWTECH
Cruising
It finally went, but what a pain, a lot of patience and two people, one holding the line from the outside through the inner fender and another pushing with everything he had! Thanks all!
To Throw out bearing install
