HVAC Backlighting
It has been one of the most frustrating consoles I have ever tackled. My HVAC works fine, I just don't have any backlighting on the buttons. The display itself is fine. I did see a offer on eBay where they will send you a refurbished unit for $200 and when you return your unit you get $25 back but I'm not so sure this issue (although it does drive me crazy) is worth it. I'm definitely not buy a new one for over $350 though. Hopefully someone will see this posting that has "been there and done that"
Here is a close up of one of the bulbs. Anyone know where to obtain them?
Is it possible that all of the bulbs are blown? That would be a bit odd wouldn't it? I did check them for continuity and from post to post of each of the bulbs there appears to be none. I also looked very closely at the solder joints on the board and I don't see any that appear broken or questionable.
Last edited by msmith56; Aug 8, 2014 at 10:59 AM. Reason: Added to what I have done
EVRose, Thank you so much for your help on this! They are in fact blue covers. I initially did not think that they were removable but they are. They are a little difficult to remove (I did tear one while trying to remove it). Despite my thinking that all the bulbs couldn't possibly be bad, I decided to move forward with my quest. I unsoldered and removed all 7 of the bulbs. Radio Shack has a bulb that worked out perfect for me. It's item 272-1154 and my local store had them in stock.
I soldered in the new bulbs and tested. All of the buttons are now lit and look great (with the exception of the cap that I tore the cap off of)
Here is a synopsis for anyone else who may find this information helpful:
1) The HVAC is held into the console by 2 screws/ bolts.
2) There are 3 plugs in the back of the HVAC. The 2 blue ones were easy to remove, the white one was more difficult. I had to use a flat tip screwdriver to lift the tab on the top and then remove the plug.
3) There are 4 screws / bolts in the back of the HVAC that need to be removed to access the bulbs.
4) Once these are out, Gently push on the ***** to push the circuit board out of the enclosure.
5) There is a white rubber gasket on the top of the bulbs. It is secured by rubber nubs that go through the circuit board. Gently pull up on the gasket to pull it away from the circuit board.
6) Unsolder the 7 bulbs or the bulb(s) that are/is not lit.
7) Solder in the new bulb(s)
8) Put the rubber gasket back over the bulbs. The rubber nubs do not go back in easily however I used a very small allen wrench and inserted it into the small hole above the nub and they all went in easily.
10) Put the face of the HVAC on a soft surface and make sure that the fan control plastic pieces are in and seated behind the fan control button. The control won't work with them.
11) Set the back of the HVAC onto the face carefully, It should fit easily and there are some guides that will position it correctly.
12) Put the 4 screws / bolts back in and tighten.
13) Install in the car, turn on the lights and see if you were successful.
