I bought a used DTE transmission and differential brace off of the for sale section here. But the seller did not have the installation instructions. I assumed they would be easy to find online but unfortunately I can't find them. I've searched Google and here and all I've found are broken links. Does anybody have some installation instructions they can send me a copy of? Or know where I can find them online? My car is an 05 base manual transmission. Thanks in advance.
I hope you plan on installing with the driveline out of the car - it will save you a ton of time and 4 letter words. if not, put band-aids on your knuckles now...
Just so you understand....that brace won't save your azz!
What do you mean it wont save my AZZ? Its gotta be better than stock right?
Thanks for the replys guys.
My point is don't feel like that brace will keep the diff from splitting. It may or may not prolong it but it also may give you false confidence. If you have any power adders it's to your advantage to replace it while you still have a core value...once broken it's junk.
