PRW Water Pumps
Had anyone installed a PRW water pump? They only show an LS1 application, but id should work on the LS2. May not get to it for a couple weeks, but I will let everyone know what it is like.
http://www.prw-usa.com/3715
There hasn't been much said about after market water pumps.
It doesn't help you at all but it's all I have:
http://forums.corvetteforum.com/c6-c...ater-pump.html
LS1 and LS2 timing cover has distinct difference in clearance. LS1 has more clearance for water pump choice. So....If if is listed for LS1...well...
I tried an Evans, from the get go, ran into major interference with their impeller cover top mounting bose, spoke to Evans engineers, got their ok, grind to the limit to provide clearance, blue checked moved onto another area, one step at a time, blue checked to confirmed clearance, over three days with slow and progressive removal of interference to ensure precise blueing fit up check.....eventually, stop short, confirming with blue check, when I need to grind my OEM timing cover. Evans was along the ride during my fit up process, they admitted pumped was never designed for an LS2, asked for my return of the modded pump and promptly refunded in full with shipping.
I'd spoken to member Pumba over at Autocrossing, he is using an Evans, although designed for LS1, he had to do some heavy clearance grinding to fit, using on his tricked out C5Z.
IMO, although lacking ceramic bearing seals, Edlebrock is my choice when the time comes.
The billet pulley is really wide, so you need to make sure the power steering line doesn't rub on it.
I would buy again.
I would buy again.
Like most everything else I bought for the front of the engine, I bought it for looks, but they do have documentation that says it flows better than the stock pump. I had a Billet-Tech Alternator with a billet pulley, a Turn1 Power steering pump with a billet pulley, Katech idler with a billet pulley, so I had to have a billet water pump pulley so they all would match.
https://www.prw-usa.com/product/1434...vette-polished
The Meziere pushes a constant 55 gph where as the stock pump is ( I think ) 22 gph?
With the Meziere, a DeWitts radiator and a big oil cooler, my car ProCharged car NEVER overheated.
