Transmission cooler
I read my vehicle should have already a transmission cooler but I have not located it, regardless, I was wondering :
1) should i replace the tranny cooler?
2) how can I get to show the tranny temps
3) what is a good tranny cooler and how much it would set me off?
I'm not looking for super hi end performance, just something that will preserve my transmission in the right working temperature ranges even when I occasionally push it or bring it to the road course.
During my Touring driving I feel a lot of heat from the center console is that normal?
Thank you
Thank you
during normal driving while moving the cooling fluid sits at around 194F, oil at 210F.
when road is open and on twisty bits with hairpin usually cooling fluid goes up around 208+F rands and Oil in the 230+F
ambient 75-80F
are those in the norm and will I be fine for repetitive consistent lapping?
Thax Ernie for the answers so far
ambient 75-80F
maybe if you like it and find yourself getting faster a Dewitts radiator will fill the bill for as long as you continue with a stock engine and quite a bit after. brakes are more of a concern later
