Hot center console
Old Aug 12, 2014 | 03:23 PM
Vettelvr50's Avatar
Vettelvr50
Default Hot center console
I have a '12 and the center console gets really hot. Has anyone got a remedy for alleviating the heat and keeping the items in the console from not melting???
Old Aug 12, 2014 | 04:03 PM
HBsurfer's Avatar
HBsurfer
There is an insulator pad made to fit in there. It helps. Search Top Flight Reproductions on this forum. I think it is about $20
Old Aug 12, 2014 | 06:16 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Another option is to install an insulated tunnel plate from www.eliteengineeringusa.com ; significantly reduced heat in my console.
Old Aug 12, 2014 | 09:27 PM
PMD C6's Avatar
PMD C6
Welcome to C6 ownership. Btw, The console insert helps. Or you can buy an insulation kit from one of the vendors and do the entire car.
I have read mixed reviews on the tunnel plate.
Bottom line, do your reasearch. However the insert is a quick and inexpensive solution but will not block out all of the heat. Get the cupholder insert while you are at it.
Old Aug 13, 2014 | 08:28 AM
rws.1's Avatar
rws.1
Ceramic coated tunnel plate + insulation
Old Aug 13, 2014 | 09:50 AM
bucwheat's Avatar
bucwheat
I made my own console insulator and cup inserts.it helps. With the heat.
Old Aug 13, 2014 | 09:52 AM
timd38's Avatar
timd38
Same here.
To Hot center console
