Keyless entry?
Old Aug 13, 2014 | 06:34 PM
Tobias Ernelind's Avatar
Tobias Ernelind
Cruising
Default Keyless entry?
Hello! I've been a little while since become the happy owner of a C6 Z51 -07 :-)
But unfortunately, I have a little trouble getting into the driver's door from the outside, from the inside, it is no problem whatsoever. The passenger door works fine to enter in & outside. Proposal?
Have tried to change the "touch panel" from the passenger door with no luck. Have also tried to change the battery in F0B without success.
Thanks in advance.
// Tobbe Sweden
Old Aug 14, 2014 | 08:59 AM
Dano523's Avatar
Dano523
Try pulling the door pads apart and cleaning them.
http://forums.corvetteforum.com/c6-c...-fix-easy.html
Also, if the door pads need cleaning, then bank that you need to pull the rear hatch releae button above the license plate and clean it at well.
http://forums.corvetteforum.com/c6-c...-pictures.html
Old Aug 14, 2014 | 07:14 PM
Tobias Ernelind
Cruising
Hello!
thanks for the reply!
I have today taken apart door pad with no luck:-(
Have also had disassembled the door latch on the driver's door, no direct fault there either.?
Will check on the rear hatch release button tomorrow.
Just thought of one thing, it may not have anything to do with that I only have one FOB?
It may need to be reprogrammed ???
A few more tips?
thanks in advance!
Old Aug 21, 2014 | 08:19 PM
MLRS's Avatar
MLRS
I do have exactly the same problem, have you come with a fix.
Old Aug 22, 2014 | 07:12 AM
dmoneychris's Avatar
dmoneychris
I had this issue come up w/the 2008 that I had. A bit of Lithium grease in the gear where the door mechanism does it's thing had worked for a little while. In the end though, the whole door mechanism had to be replaced, that little engine that could, could not any more.
Old Dec 22, 2014 | 03:25 PM
Tobias Ernelind
Cruising
Hello again
Unfortunately, the problem remains with the door Any more ideas? There were no error codes on the door in our workshop.
Could it be the wiring harness? Lock case?
Thanks in advance
Old Dec 22, 2014 | 04:45 PM
RicK T's Avatar
RicK T
Possibly the door lock module.
https://www.corvetteforum.com/forums...xperience.html
Old Dec 22, 2014 | 05:09 PM
Tobias Ernelind
Cruising
Originally Posted by RicK T
Where is it located? It can only go broke? Can they be also fixed the door can be opened from the inside? Does it only with the driver's door to do? What is the original number of the part?
Old Dec 23, 2014 | 01:02 AM
Dano523's Avatar
Dano523
If you push the door release button on the inside of the car door, does the window index down and the door opens. And again, the push button on the door, and not the emergency release handle down on the floor.
If the window indexes down, the door opens when you push the inside button, then the locking latch itself is fine.
So that moves us back to either the pull pad on the door being corrode and needs to be cleaned, or the harnesses in the door for the wiring is loose/you have a broken wire instead, and why the car is not getting a signal from the door pad, but the interior button instead.
Old Dec 23, 2014 | 04:40 PM
Bill Dearborn's Avatar
Bill Dearborn
If the door doesn't open using the outside button but it does open using the inside button the problem is with the door pad. Clean, swap with the pad on the other side of the car or replace. If neither the outside pad or inside switch open the door the problem can be with the control module inside the door or with the latch in the B pillar. Usually if you are having problems with the door control module there are problems with the window not indexing properly.
Bill
Old Dec 26, 2014 | 11:42 AM
Tobias Ernelind
Cruising
Hello again!
Yes the window senses when I press the button, so the window goes down.
The pull pads, I have tried to change from the other side without success. Have even taken it down on the driver's side and made clean it without success.
Ideas?
thanks Tobbe
Old Dec 31, 2014 | 03:07 AM
SlowBusa08's Avatar
SlowBusa08
Originally Posted by Tobias Ernelind
Hello again!
Ideas?
thanks Tobbe
Sounds like you have a wiring problem inside the door between the connection inside the door and the outside door pad.
To Keyless entry?
