Alignment?
Old Aug 14, 2014 | 06:08 PM
SSWEET's Avatar
SSWEET
Default Alignment?
Got a Pfadt street alignment when I put new Bridgestones on my GS. That was about 8k miles ago. Changing wheels GM wheels for GM wheels (same size) just a different finish, same tires...Seems to me that I'm not changing the geometry that would require another alignment. Thoughts?
Old Aug 14, 2014 | 06:12 PM
cclive's Avatar
cclive
No alignment needed unless the tires are not currently wearing straight..
Old Aug 14, 2014 | 06:22 PM
SSWEET's Avatar
SSWEET
No uneven tire wear.
Old Aug 14, 2014 | 06:37 PM
cclive's Avatar
cclive
Then put those wheels on and don't touch a thing. Make sure that they put the pressure sensors back in the same location on the car..no need for re-programming then.
Old Aug 15, 2014 | 12:45 PM
Dano523's Avatar
Dano523
Re-programing the TPMS system is a snap, and hate to say it since mine flaked out on me due to a low battery that just the system relearning the TPMS solve the flake out problems, system relearning the TPMS as tire changes is not a bad thing.
If the tire place wants to charge you for the car to relearn the TPMS locations, Discount tire does such for free.
Or, since we are talking C6 corvette, Tire rack sells the Cub Pro-101 reprogramming tool for around $30 shipped, and not a bad tool to have on hand. To add on the tool, for 2005 to 2009 corvettes, use the corvette setting on the tool. For 2010 to 2013 corvettes, use the HHR 2009 setting instead (same TPMS in the 2009 HHR that the later C-6 vetts use, so the tool works with the later C-6 corvettes, even though tire rake states it does not).
Old Aug 15, 2014 | 08:59 PM
SSWEET's Avatar
SSWEET
Ive got the green TPMS on my 2010 Grand Sport. I can add or release air to relearn them.
To Alignment?
