Sputtering probelms
Old Aug 15, 2014 | 03:24 PM
WHY TRY?'s Avatar
WHY TRY?
Default Sputtering probelms
Might've previously posted this in the wrong section, so i figured I'd try here.....http://forums.corvetteforum.com/c6-z...th-tc-off.html
Old Aug 15, 2014 | 03:45 PM
Dano523's Avatar
Dano523
P0205 Injector 5 Control Circuit ECM
http://engine-codes.com/p0205.html
Might luck out and find that that injector harness is semi unplugged (missing the keeper) and just needs to be fully plugged back in.
From there, check the wires up line for a short/burn through against the engine that is causing it to ground out.
Next up the ladder would be pull the 5 injector, swap it and another injector out with each others locations, and see if the code follows the injector (bad injector that may need to be replaced).
Old Aug 15, 2014 | 03:53 PM
WHY TRY?'s Avatar
WHY TRY?
Thanks, I'll go ahead and try that out.
Old Aug 15, 2014 | 04:57 PM
gmtech1234's Avatar
gmtech1234
First get an injector noid light. It plugs in place of the injector. Start engine, You should see the light flicker. This is checking for power to injector & the computer grounding to spray the fuel. If no flash check for power in one of the wires , probably a pink or red. The other wire goes back to the computer. Also thank you for your service!
To Sputtering probelms
