Coolant leak - somewhere...?
Before I do that, any history of a common problem source for this? Suggestions?
If not, you may be experiencing a pin hole leak from one?
Is the leak under the radiator? Could be a small leak in the radiator or your drain spigot loose.
Is it at the bottom of the engine? At the front or rear? Front of the engine could be a water pump starting to leak. Anywhere else on the engine could be a bad freeze plug.
Get the car up in the air and when it is cold feel around the back of the water pump pulley and the back of the pump for dampness or stickiness. Feel the top of the stabilizer bar as well. If that checks out then start feeling around the left side of the radiator where the plastic tank meets the aluminum body. Check the spot where the radiator slips into the frame mount. Once done doing this do the same checks on the passenger side since fluid can easily move from one side to the other. Check around all hose connections and at the coolant tank.
Bill
I believe the 2nd one seemed to leak from where the plastic meets the center aluminum part on the lower driver area.
The heat expands whatever small crack there is to leak coolant, then shrinks to seal up when cool, but I had visual confirmation of coolant remnants in the area when I looked carefully.
It was still drivable with slight top offs, so actually had time to "think" instead of going straight to dealer in a panic like the first time. Had my shop order Dewitts and installed over 2.5 years ago without an issue since.
I think total cost was maybe ~$200? more than what I paid dealer on the stock replacement, so it is a no brainer if you plan to keep the car.
I am also on my 3rd water pump, so it's good to at least make the radiator bulletproof, since I hated the constant faint coolant odor after pulling into garage.
(as others have said, water pump leak would be from the bearing/seal of the rotating wheel. you can use a flashlight to shine into the backside of the big dome/wheel to see if there are any coolant remnants on the bottom edge of that wheel, since whatever doesn't get flung around forms a tiny pool in the backside of that wheel when engine is shut off.)
They are sponsoring vendor for this forum as well, you can find a link for them on the left column if using desktop site.
They are the place to go great product & great service
