tfs 255 rocker suggestions??
Old Aug 21, 2014 | 06:55 PM
lsxvette's Avatar
lsxvette
Default tfs 255 rocker suggestions??
any suggestions on a set of rockers for the tfs 255 heads ? i bought a set of jesel from a forum member that was "supposed to fit all TFS heads" but they dont ..so im at square one again ... ive heard everything from jesel to stock ls3 with the trunion upgrade ..lmk what ya think
Old Aug 21, 2014 | 07:02 PM
timd38's Avatar
timd38
What do you want to do with the car? I went with stock and comp Cams trunnions.
Old Aug 21, 2014 | 07:04 PM
lsxvette's Avatar
lsxvette
its gonna be a 1000whp street car
Old Aug 21, 2014 | 07:10 PM
timd38's Avatar
timd38
WOW, I have no clue than! Money buys speed and I don't have that much money!
Old Aug 21, 2014 | 09:03 PM
NastyChevelle's Avatar
NastyChevelle
5th Gear
Crower makes a shaft set for those heads that I've used on two cars. Work great. I'd start there!
Old Aug 22, 2014 | 12:40 PM
miami993c297's Avatar
miami993c297
Hi lsxvette,
The engine builder in charge of a "1000rwhp street car" project should be able to answer this basic question...
Christian
Old Aug 23, 2014 | 12:13 AM
lsxvette's Avatar
lsxvette
Originally Posted by miami993c297
Hi lsxvette,
Christian
thanx for the words of wizdom but i would rather make my own decision thats why i ask more then just "the engine builder" theirs nothing "basic" about a 1000rwhp build
Old Aug 24, 2014 | 07:03 AM
BOO666's Avatar
BOO666
T& D fan here .... I had same heads and stock rockers with no issues . Get the right person on those heads and they make great power . T .E . A. Built mine .
Old Aug 24, 2014 | 08:22 AM
timd38's Avatar
timd38
Let us know how your R&D project turns out! Sounds like fun.
Old Aug 24, 2014 | 01:44 PM
lt1z's Avatar
lt1z
Stock with comp trunion upgrade and the TFS supplied rocker stands. Keep lift below .630 and let the PA do the work. You don't need a shaft rocker and solid roller valve train for 1000 hp unless you are trying to do it N/A or with a small shot.
Old Aug 25, 2014 | 04:31 PM
lsxvette's Avatar
lsxvette
yea some very knowlegable people told me the same thing ..im gonna give it a shot
Old May 19, 2018 | 10:54 AM
Bigwebb's Avatar
Bigwebb
I'm looking for information on the same question... The only difference being I am looking for 510-20ish rwhp
Old May 19, 2018 | 11:19 AM
Brandon619's Avatar
Brandon619
Run Yella Terra rockers from Tony Mamo and be done.
Old May 19, 2018 | 03:34 PM
Bigwebb's Avatar
Bigwebb
this is the yella terra yt6733 ultralite rocker setup, right?
Old May 19, 2018 | 05:44 PM
Brandon619's Avatar
Brandon619
No, 6645
Old May 20, 2018 | 12:33 AM
xBoostx's Avatar
xBoostx
T&D machine makes the shaft mount roller rocker arms for the Trick flow 255 heads I have both can order several options from T&D like light weight where they cut a groove off across the center, those come with oil routed to the tip rollers which I decided against it plenty oil flying around no need for extra oil pressure bleed, mines are also adjustable.
T&D have a racers program only charge for service parts needed no service charge and quick turn around you pay for the ride.
To tfs 255 rocker suggestions??
