1/2" Studs
Old Aug 24, 2014 | 09:15 PM
Ibanez540r's Avatar
Ibanez540r
Default 1/2" Studs
Do stock 2008 5 star wheels fit over 1/2" wheel studs?
Old Aug 26, 2014 | 11:16 PM
Ibanez540r's Avatar
Ibanez540r
The birds are chirping... Helllooo, is anybody out there... ???
Old Aug 27, 2014 | 11:40 AM
irok's Avatar
irok
they are made to fit a 12mm stud
Old Aug 27, 2014 | 01:33 PM
Bill Dearborn's Avatar
Bill Dearborn
12 mm is just a shade under a 1/2 inch at .472 inch. 1/2 inch is 12.7 mm. Sort of depends on how much larger than 12 mm the hole in the wheel is. I know the hole is larger than the stud since they go on easily without catching any threads but don't know how much larger they are.
Bill
Old Aug 27, 2014 | 10:41 PM
HOXXOH's Avatar
HOXXOH
You also need to identify the wheels a little bit better. Simply 5 star is not quite enough.
Go here to see choices.
http://www.corvetteactioncenter.com/...ring_guide.pdf
See page 45 and 46.
The stud hole ID on a QX3 is a minimum of .590, but less than .660. I assume the others follow suit, but that's all I had loose to check.
These wheels are hub centric, so the hub ID is also important.
Old Aug 27, 2014 | 11:19 PM
Ibanez540r's Avatar
Ibanez540r
Bill
See page 45 and 46.
I am referring to the QX3. I planned on getting the wheels and my dial caliper out, but thought I would ask here first. Also wanted to hear first hand experience, if any.
Based on both of your info, .472 to the .590-.660 sound like they should fit fine.
Thanks guys.
Old Aug 28, 2014 | 08:33 AM
timd38's Avatar
timd38
Are they hub or stud centered? Corvettes are hub centered. That is why Corvette specific wheel spacers have a ridge on them.
Old Aug 28, 2014 | 02:14 PM
Ibanez540r's Avatar
Ibanez540r
Hub
To 1/2" Studs
