Passenger window screeching noise
Old Aug 25, 2014 | 03:46 PM
Jose2SS's Avatar
Jose2SS
Default Passenger window screeching noise
Hello, this started to happen last week, when the passenger window goes down it makes a screetching noise, any ideas???
Old Aug 25, 2014 | 04:25 PM
Cherokee Nation's Avatar
Cherokee Nation
My 08 was doing the same,then it went dead! Would not roll up or down.Dealer replaced the regulator.No problem since..Good Luck
Old Aug 25, 2014 | 06:41 PM
Jose2SS's Avatar
Jose2SS
Thanks, was evading the dealer visit.
Old Aug 25, 2014 | 06:54 PM
Cherokee Nation
So was I,but i have a GMPP & the cost was around $1100.I've heard some guys replaced them their self.Easy fix if that is your problem....
Old Aug 26, 2014 | 06:09 AM
Homeboy77's Avatar
Homeboy77
I had the wire on mine start to fray and catch in the motor. That was the screeching noise. Soon after it died because the wires were too tangled in the motor. It is an easy replacement. Just mark the glass carefully on the new regulator because you want your window to align correct for opening and closing. Maybe use a marker and outline the glass around the tabs of old regulator to new.
To Passenger window screeching noise
