C6 gear shift adpter
Old Sep 4, 2014 | 10:05 AM
riverrat68's Avatar
riverrat68
Default C6 gear shift adpter
I have a threaded gear shift ball I would like to put in mt C6 GS, does anyone out there know who makes an adapter for the C6 stick, that will allow you to do that?
Old Sep 4, 2014 | 12:30 PM
timd38's Avatar
timd38
B&M , Hurst, MGW all make shifters that will take a threaded ball.
Old Sep 4, 2014 | 04:48 PM
riverrat68's Avatar
riverrat68
I know they all make the shifters. I am looking for an adapter to go on the stock C6 shifter that will allow you to put a threaded ball on it.
Old Sep 4, 2014 | 10:14 PM
Dano523's Avatar
Dano523
Adapter would end up with the shift ball being higher than normal.
The problem is that the round section of the C-6 shaft is wider than a C-5 threaded section, so you would need to have the threads above the sleeve section of the adapter that would bolt onto the shaft.
C6 shaft on top, and C-5 shaft on the bottom.
So on that note, you are better off just getting a C6 ball shifter that is already set up to side bolt to the standard C-6 shaft.
Old Sep 4, 2014 | 11:59 PM
riverrat68's Avatar
riverrat68
Thanks guys. I guess I will stay with the stock one.
Old Sep 5, 2014 | 10:39 AM
victorf's Avatar
victorf
Lots of options, here are a couple of samples, which are somewhat closed to your perspective, if you want to stay with an OEM shaft:
1. OEM shifter assembly can be mounted, then indicated on an lathe using four jaws. Shorten to any length desired, then externally threaded, for internal threaded ***** with 9/16 x 18 threads or any thread type.
2. I believe this option is what you are asking. OEM shift shaft excess length above set screw dimple can be cut off, if **** sitting high bothers you. An adapter made with any material of your choice. Machined one end with female receptacle (drilled/taped on OD for set screw), sized to fit over OEM shaft, then secured onto dimple on OEM shaft. With opposite male end (single point, cut to any desired thread pitch), for shift ***** of your choice with internal thread. It sounds a little complicated than what it really is.
Any competent machine shop can easily do the above and came out looking pretty. If they are willing that is, but won't be cheap.
Here is my mirror polished and heat treated titanium ****, although it is not for an OEM shaft, just to illustrate possibilities:
Old Sep 5, 2014 | 06:49 PM
riverrat68's Avatar
riverrat68
I never new how much I liked the stock shiter till now.
Old Sep 5, 2014 | 07:18 PM
timd38's Avatar
timd38
Sometimes thing are best left alone!
Old Sep 6, 2014 | 02:25 PM
victorf's Avatar
victorf
^^^For some people that is true, especially without resource!
But your imagination is living prove on your wonderfully modded C6.
Or another instance, member Pumba's out of bound, tasteful C5Z.
Old Sep 6, 2014 | 02:37 PM
timd38's Avatar
timd38
Yup! I will not confess on what I spent on a pair of Recaro seats and custom brackets. Had then in for less than one day before I put the old seats back in. New and custom isn't always better!
Old Sep 6, 2014 | 03:51 PM
victorf's Avatar
victorf
That is so true that money not necessary comes with satisfaction. Especially an "expensive custom" is designed, at the mercy of the maker.
But other time, resource can also define as having the know how as well as equipment to fulfill one's own imaginations without compromise.
To C6 gear shift adpter
