p0872 trans pressure sensor... please help!
Old Sep 5, 2014 | 12:43 PM
el es tu's Avatar
el es tu
Default p0872 trans pressure sensor... please help!
accidently posted this in general - I know more folks are likely to check it here - sorry for the dupe!
i was just accelerating onto the highway in 1st and tried to shift at 4k - and the car started bucking like it was hitting the rev limiter
I scanned it and got a p0872 transmission fluid pressure sensor/switch c circuit low (history) (immature)
I have had some issues with the trans shifting wonky in the past - im wondering if its a sensor or the harness... where is this located, how hard is it to replace (if I should even replace it all all???) and is it expensive?
I want to get an idea asap so I can get my dealership to order the part and change it out this weekend.
Thanks!
EDIT:
PM'd a well respected forum member on the subject - apparently this will come and go as the car wears. The solution is to clear the codes and clean out the trans fluid. I will be dropping the pan and putting a new filter to alleviate any possibility of this coming back sometime soon...
Took the car for a drive earlier and let it rip to 6000+ before shifting and didnt have any issues. I guess as stout as the 6l80 is it can have minor issues just as any other auto
notes - the filter to use is a duralast tf501 which is the same as the delco factory
fluid 6.5l dexron
