constant stalling after cam install
Old Sep 6, 2014 | 11:48 AM
telly444's Avatar
telly444
Default constant stalling after cam install
so I just had my WCCH and Kaotik Cam installed on my E force supercharged Z06 and soon as you let off the gas she wants to stall. maybe my mechanic missed a vaccumm line or something is leaking? I should be able to at least drive the car to get tuned without it stalling? I need to commute 300 miles to a tuner.
Old Sep 6, 2014 | 01:11 PM
Pitufina's Avatar
Pitufina
It doesn't sound like the injectors were replaced but I can certainly see that it does have a lot more airflow. The idle/air bleed etc needs to be adjusted to compensate for the cam. You know it needs to be tuned, but if the injectors were replaced be careful that it may be running too rich and can wash the cylinders. Any codes?
Old Sep 6, 2014 | 01:13 PM
telly444's Avatar
telly444
No injectors other than the 60lbs one that come with the e force kit. It's going to get a boost a pump installed Monday. Yes I know it needs a tune, but my tuner is a few hours away. No codes.
Old Sep 6, 2014 | 01:40 PM
nullpointer's Avatar
nullpointer
Nope, depending on how much the airflow characteristics changed from the cam/head swap your current tune may not be able to return to idle properly. If stalling is your only problem then you can probably limp it to the tuner, stop signs and lights will get annoying (just give it some gas). Do not go WOT until you are fully tuned.
Old Sep 6, 2014 | 01:48 PM
telly444's Avatar
telly444
WCCH ported heads and big cam. lol lots of flow now. I guess my question was is this normal for a untuned cam swap.
Old Sep 6, 2014 | 01:49 PM
nullpointer
Yep
Old Sep 6, 2014 | 02:17 PM
telly444's Avatar
telly444
thanks guys.
Old Sep 7, 2014 | 07:56 AM
old motorhead's Avatar
old motorhead
I might drive it a little ways running like it is. No way I'd drive it 300 miles. Rent a trailer and tow the thing. I think you're asking for trouble.
Old Sep 7, 2014 | 08:11 AM
telly444's Avatar
telly444
Yeah I'm doing an email tune from ed at HiTech. Do a few logs, couple tweaks and leave it at that for the season.
To constant stalling after cam install
