help! starting issues.
Old Sep 6, 2014 | 02:13 PM
Dtownbrown's Avatar
Dtownbrown
Default help! starting issues.
Okay, so car has always started and ran perfect. Done a cam swap over the weekend. Started just fine initially. Drove it 2 miles, then suddenly my oil pressure, fuel gauge, and temp gauge went to 0. Got to the parts store and killed the car and unhooked battery cable thinking I would try re setting the ecm.
Came outside several minutes later, hooked battery back up and when I hit the start button the instrument panel goes dead for a few seconds and then comes back on. So I thought dead battery, swapped batteries and still no difference . Iv checked all fuses and relays and have not been able to figure it out.
Could this be a theft deterrent symptom?
Info on my car
2005 c6 6 spd base
408 stroker f1r procharger
