LS7/Z06 harness and sensor differences?
Old Sep 9, 2014 | 05:27 AM
Chance9121's Avatar
Chance9121
Default LS7/Z06 harness and sensor differences?
Hey everyone. I've noted that GMPP sells two different harnesses for the LS7. As well, it seems 06-07 and 08+ had a difference between the engine, harness, and fuse layout. It seems very minor. According to one search:
"The 07 and 08 wiring harness has 2 wire pinout differences and you could have swapped those pinouts. Did it on mine except mine was 08 with 07 engine harness.
1 wire was in the harness at the #72 pin in the ECM plug and the other was at the underhood fuse block X3.
Mine had the same symptom. Push the start button and everything shut down. Took about 8 seconds then everything returned to normal until the button was pushed again.
Need to make sure you have the right underhood fuse block as 07 and 08 are different.
What I was wondering is if anyone knew if there are different sensors on the motor's themselves, and if you can swap the sensors to fit the ecm/harness from a different year. Such as you have an 07 motor with a complete 08 engine harness/body harness/ecm. I am working on a project and this would help to know, so I don't mix up my parts.
If anyone knows the sensor compatibility, please let me know. I can't find it so far in my searching.
Old Sep 9, 2014 | 07:11 AM
timd38's Avatar
timd38
If you give them you VIN, they should be able to get you the correct one.
Just a guess based on history.
Old Sep 9, 2014 | 11:18 AM
Chance9121's Avatar
Chance9121
The problem is its not for a Z06, is all. Just the motor into another vehicle. Don't have an original vin, but I may be able to figure it out based on engine setup. Not a big deal but it could catch me if I don't figure the issue out before I wire things up.
Old Sep 9, 2014 | 11:35 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Yes, some of the sensors are different.
19258553 Replaces 19166567 LS7 Controller Kit 2006-2008
LS7 Controller Kit • Will only work with 2006-2008 LS7 P/N 17802397 • Includes all the components required to run your GM Performance Parts crate engine
(see chart below for detailed list) For individual engine controller, use P/N 19166569 (included in kit)
The kit includes the following items:
• 19268554 Engine Controler
• 19166573 Engine Harness
• 15865791 Mass Air Flow Meter
• 19166574 Mass Air Flow Meter Mounting Boss
• 10379038 Accelerator Pedal Assembly
• 12581966 Oxygen Sensor (Qty 2 Per Kit)
• 15156588 Oxygen Sensor Mounting Boss (Qty 2 Per Kit)
• 19171935 Instruction Sheet
19258553 replaces 19243066 LS7 Controller Kit 2009
LS7 Controller Kit
• Will only work with LS7 P/N 19211710
• Will not work on 2006-2008 LS7 P/N 17802397 • Includes all the components required to run your GM Performance Parts crate engine
• 19253067 Engine Controler
• 19202595 Engine Harness
Old Sep 9, 2014 | 11:44 AM
Chance9121's Avatar
Chance9121
LS7 Controller Kit
So is the assumption if I but the 09 kit, and I supply a bare block/heads with 09+ sensors from GM, I won't have an issue. I.E. its the same crank trigger and sensors are in the same location? From what I can tell, the big changes were gen III/Gen IV which don't affect the LS7. Did they use an update crank/cam sensor or something?
I'll keep looking, if I find an answer I'll come back with it, or if someone else knows, that would help. Thanks for the help so far.
To LS7/Z06 harness and sensor differences?
