Hey fellas ! Just looking for a little butof info hopefully someone can point me in the right direction or answer them .
1. What all do I need to set this up on my 06 base C6 ( LS2)
2. Anyone in here have it for sale ?
3. Is there any welding that needs to be done or is it just bolt on ?
3. Some welding is required, and adjustments/light fabrication may be necessary, depending on what donor car they came from and how they match up to your car.
3. Some welding is required, and adjustments/light fabrication may be necessary, depending on what donor car they came from and how they match up to your car.[/QUOTE
I figured there was but I'm on my phone so I can't search anything aha and I'm confined to this for a fee days . But what I was planning on doing was just going to GM and buying everything new through them since I get wholesale through them .
I'm just wondering what'd be the overall easiest and best fitment
Thanks in advance
I have a 2006 and I just did this. All you need is some npp mufflers from a 2008 non Z06 vette. I also used a npp in the box so I could control them with a remote. No welding what so ever. Simple take your old mufflers off and bolt these on, perfect fit. I found my used npp mufflers with the npp in a box on ebay. Sounds great!
I have a 2006 and I just did this. All you need is some npp mufflers from a 2008 non Z06 vette. I also used a npp in the box so I could control them with a remote. No welding what so ever. Simple take your old mufflers off and bolt these on, perfect fit. I found my used npp mufflers with the npp I'min a box on ebay. Sounds great!
thank you !!! Appreciate the knowledge . Did you end up doing the npp in a box yourself ? The mufflers shouldn't give me a problem
Yes I did the npp in a box myself. I ran the vacuum line while I had the mufflers out, lot more room. I teed off the front of the manifold for vacuum. If you buy new npp in a box it comes with the the T to do it that way. It was easy and I'm 67.
Yeah but that's 67 years of knowledge! Aha thank you though appreciate all the help
