C6 Low Beam Recall and A6 Shift Issue
Old Sep 11, 2014 | 02:29 PM
wpbailey's Avatar
wpbailey
Originally Posted by QKSLVRZ
I would worry that they killed the TCM when they were disconnecting/connecting power (if they bothered at first). I don't know how you can prove that though.
That scenario fits the symptoms.
Old Sep 18, 2014 | 10:50 AM
wpbailey's Avatar
wpbailey
Default Results from meeting with the Service Mgr at the Dealership
Originally Posted by wpbailey
The TCM will not be installed until early next week. I will post the results of that repair. Stay tuned in.
I meet with the Service Mgr at the Dealership and the meeting did not turn out well. The Service Mgr took the position that the A6 shifting issue, security and "check Engine" caution warning lights, along with the intermittent operation of the speedometer issues were all coincidental failures and had were not caused by the installation of the fuse block. He took his position in spite of the fact that all four issues presenter themselves at the same time the fuse block was replaced. His justification for his position was that the car was seven years old and the parts fail at some point. Hence it was just a coincidence that all failed on the day the repairs were done. My vette has 65,000 miles on it at this point. His final stance was that we would have to "agree to disagree". I was charged an additional $250 for the additional testing that indicated the TCM was faulty. I did not authorize any further work be done on the car by the dealership. I cannot allow them to make a profit from me while they are using their current business practices.
I have gone to another reputable mechanic and asked him to render a second opinion. I have provided all the test results provided by the Dealer. I asked him do three things. First, find out what needs to be done to cure the current issues with the car. Second, render an opinion as to why these issues all occurred at the same time. Third, repair the current issues with the car. This will take a few more days. I will report the findings as they are available.
Old Sep 19, 2014 | 03:32 AM
torquetube's Avatar
torquetube
In addition to having no honor, these guys sound like incompetent part swappers. Don't give them any more opportunities to screw up your car, even if they're willing to work on it for free.
How old is your battery?
Old Sep 23, 2014 | 08:42 PM
wpbailey's Avatar
wpbailey
My C6 is now back in good health. The results of the analysis of the second independent analysis is that the TCM failure was not a caused by the work done to replace the Fuse Block. In short, the dealer got it right. The TCM failure was a coincidence that it happened at the same time the fuse block was replaced.
The work done on the C6 was as follows:
Service manager notes: codes present -U- 0101 and P-2544. Need to replace the transmission control module. Will need to remove the transmission pan in order to access the control module which is part of the transmission valve body. Replace pan gasket and refill with synthetic transmission fluid. Reprogram the trans module when repairs are completed.
Parts list:
24238968 Trans Control Module
24224781 Trans Filter
ATF DexvIII Dextron "H" Syn
24239878 Electric Connector Slee
254236928 Sleve Seal o-rings
Cost for the TCM repair was $1,361.63
My C6 is now running as well as it ever did. I think it was worth getting the second opinion. It was good to get to the bottom of this.
Old Sep 24, 2014 | 05:57 PM
BranC85's Avatar
BranC85
I would be curious to know how this turns out for you. Can you post the results of your experience? You may want to ask them if they have any knowledge of how the TCM can be damaged during the Fuse Block replacement. What happens if they do not disconnect the battery during the replacement?
Well I had it at the service center for the second time yesterday. The first time I had it there, they said they were not able to finish looking it over and checking all of the connections in time even though I left it for the day. I left it again yesterday and they said they thought it was fixed and could not recreate the problem. Well it didn't last long because the lights started acting up again on the drive home. I'm not sure about if they fail to disconnect the battery, but I do know they disconnected mine because the windows needed re-indexed which I did using that hold-the-switches thing. So far they have not changed me because of all the pestering I did that got me in touch with the corporate office which is nice, and I guess is the only thing keeping me from getting pretty mad about having to leave it there for the third time.
Old Sep 28, 2014 | 06:17 PM
3X2's Avatar
3X2
Doesn't your car have a 7 year/100,000 mile powertrain warranty? I would think the tcm is a covered powertrain part. Even if you are over the 7 year timeframe, the dealer should have authorized the repair under warranty.
Old Dec 15, 2014 | 02:38 PM
Dutch702's Avatar
Dutch702
How come this doesn't cover c6 z06? Its the same fuse box essencially.
