No key, glovebox lock removal
Old Sep 14, 2014 | 07:02 PM
Wickster's Avatar
Wickster
Default No key, glovebox lock removal
How do I remove the glovebox lock if I do not have the key? I bought a glovebox from a member and would like to put my lock in so I can lock it.
I have done a search and found how to change the lock if I have a key.
I also tried my key in the off chance they were the same.....nope.
Old Sep 14, 2014 | 07:20 PM
timd38's Avatar
timd38
Two screws hold it on from the backside.
Then do this.
Lock Assembly - Instrument Panel Compartment Handle
Tip:
1. Insert a small pointed tool into the lock release hole.
2. Pull the lock assembly from the instrument panel compartment handle.
Old Sep 14, 2014 | 07:41 PM
Wickster's Avatar
Wickster
Thanks for the info but it was my understanding you had to have the correct key. With this knowledge I tried it a few times to no avail and gave up but I thought I would try one more time. Not sure how but it came out and I now have the correct lock in my new box.
Old Sep 14, 2014 | 07:58 PM
timd38's Avatar
timd38
I took the info from the shop manual, not talk of needing a key.
To No key, glovebox lock removal
