Poly Bushings
Old Sep 22, 2014 | 11:11 AM
MCharlie's Avatar
MCharlie
Ham Radio - W7RKN
Default Poly Bushings
What reason, if any, would I want to change out my rubber bushings on my upgraded Z51 sway bars, to poly bushings? i don't hot rod, race, autocross, or participate in any speed events. I do like to drive hard and fast (Really??!) on the highways, and like to push the car in turns, of which we have a lot here in the Sierra Mountain Range!
If I did change the bushings, what differences would I experience? Harsher (Is that a word??) turns, more 'road feel'? Etc.
Or...
Would it be a waste of money?
Thanks!
MC
Old Sep 22, 2014 | 11:13 AM
timd38's Avatar
timd38
Waste of money based on what you said above.
Just my opinion.
Old Sep 22, 2014 | 11:35 AM
MCharlie's Avatar
MCharlie
Ham Radio - W7RKN
Just my opinion.
Tim...This is exactly the type of responses I am looking for, honest opinions and thoughts.
Seriously, thank you.
Any more??!!!
MC
RicK T's Avatar
RicK T
I don't think you need them. They "firm up" the mounting points, eliminating any "rubber squish" of the stock bushings. They "sharpen" the handling, making the car feel more like a single piece rather than bolted together pieces. Obviously important on a race car or for drivers who like to squeeze the last "thousandth" out even on a street car. Some say it makes a street car too harsh to enjoy. That is a very subjective and personal thing and every one is different. YMMV
Old Sep 22, 2014 | 11:38 AM
MCharlie's Avatar
MCharlie
Ham Radio - W7RKN
Thank you Rick...
Again, your wisdom about the car has helped guide what I do, or will do, to the car.....
MC
Old Sep 22, 2014 | 12:07 PM
RicK T's Avatar
RicK T
Well, it's only money. You could try them and if you don't like them go back to stock.
Old Sep 23, 2014 | 01:09 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
rubber allows for a little "give" poly does not. For what you said..do not waste your money.
Old Sep 23, 2014 | 05:33 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Poly doesn't always, but other types can squeak like delrin. Some say using the right lube on it prior to install and done fairly liberally will eliminate squeak forever. Maybe so. Cars I've ridden in with any kind of aftermarket bushings tend to squeak for whatever reason. Maybe it's just that lube is always changing (getting better) and it's old-tech lube that was used. Supposedly, Energy Suspension makes good stuff to cure that, but you can't cure the fact that it does stiffen things up if that's not to your liking. On the other hand, rubber does deform over time and eventually wears out and usually sooner than other materials.
To Poly Bushings
