Anyone else ever experience this? I have an 05 M6 and have been getting this a lot lately. DIC flashes back and forth "reduced engine power and service traction control system". I had it in to a Chevy Dealer and they told me it was the throttle body. I had them replace it and it's still coming up. Any help or suggestions would be greatly appreciated. Thanks.
I had a similar problem when I added a ported throttle body to my 2000 vert. vendor claimed it was installed wrong. I went to a higher flow throttle body and had the vert street tuned and the problem never returned.
There are a number of reasons for REP. If they read the code that resulted and it was one of several that involve the throttle body, it could also be faulty/damaged wiring, bad throttle body connector, bad ECU, and faulty gas peddle sensor. The dealer has more work to do.
Thanks for the info Jim! I made another appointment to follow up on this. Service Manager pretty much mentioned all the same items as you did.
