Dual mode exhaust question
Old Oct 4, 2014 | 11:05 AM
slow-v6's Avatar
slow-v6
Default Dual mode exhaust question
I searched but could not find an exact answer. I have a 13 gs and it has the stock, non npp mufflers on it. If I install a set of 2012 dual mode mufflers from a grandsport but do not hook up the dual mode function, will the mufflers be in the closed position or open?
Old Oct 4, 2014 | 12:15 PM
bobeast's Avatar
bobeast
Well. most of us pull the fuse to have them remain open, which would seem to indicate that the natural position is open.
Old Oct 4, 2014 | 12:47 PM
slow-v6's Avatar
slow-v6
Nice. Thanks for the info.
Old Oct 4, 2014 | 02:28 PM
jsucraig's Avatar
jsucraig
It takes vacuum to open them and electricity to shut them. The valves are electrically powered closed, but by 3500 RPM the Vacuum force exerted on the valves overcomes the electrical actuators and the valves open. If there is no vacuum they will not open. This is why you need to by NPP in a box to have Dual Mode Exhaust on a non RPO Code NPP Corvette.
Old Oct 4, 2014 | 06:35 PM
HOXXOH's Avatar
HOXXOH
There's just a little problem with that explanation. Under hard acceleration, the engine develops nearly zero vacuum, but generates 30 in hg upon deceleration. I think you got it backwards.
Old Oct 4, 2014 | 06:56 PM
Speedforhire's Avatar
Speedforhire
Actually, they are spring loaded in the open position by design. In an oem setup, vacuum forces them closed and an electrical signal opens them below 1250rpms and above 3500rpms. They are closed in-between to reduce highway drone under normal driving.
Yes OP, they will be open all the time if you install them without hooking them up.
FWIW! I pulled the fuse the instant I got the car home from the stealership and they've been that way since.
Old Oct 4, 2014 | 07:11 PM
haljensen's Avatar
haljensen
Wrong! At the very least it's backward.
It takes engine vacuum to CLOSE the flaps. The force used is vacuum, the vacuum is switched by electricity.
Easy to check. Look at the flaps with the engine off (no vacuum), they are open.
Look at the flaps with the engine running (vacuum!), they are closed UNLESS you ELECTRICALLY turn off the vaccum.
Old Oct 4, 2014 | 08:05 PM
slow-v6's Avatar
slow-v6
Great info everyone. Thanks for the help. Just picked up a set today.
Old Oct 4, 2014 | 11:00 PM
jsucraig's Avatar
jsucraig
You are all correct I was in a hurry between projects in the garage. I only came in long enough to do some Forum Research. I happened upon this thread and in my haste to help out I typed exactly the opposite of what i was thinking.
Old Oct 5, 2014 | 11:19 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
that was funny.
Old Oct 6, 2014 | 06:17 AM
Suds's Avatar
Suds
Default Thanks for the laugh
I just got a good laugh out of that and I'm sitting in a plane on a flight delay before the 10 hour flight starts
Old Oct 6, 2014 | 11:09 AM
jsucraig's Avatar
jsucraig
Laugh it up Fuzzballs!
Old Oct 8, 2014 | 11:10 AM
AIR_RAM's Avatar
AIR_RAM
This is why they are open when the car is off... also when you fire it up there is a split second where it roars then quiets down as it closes... So they are OPEN when power is off.
SPEED SAFE, AIR RAM
To Dual mode exhaust question
