c6 (z06) clutch bleeding
Old Oct 5, 2014 | 09:15 PM
Timz06's Avatar
Timz06
Default c6 (z06) clutch bleeding
My clutch pedal went to the floor the other day. I tried pumping, changing the fluid with a turkey baster no luck.
The next step is to get at the slave bleed but I cannot see where it is. I saw a bunch of old threads about this but there don't seem to be any that still have pictures.
Anyone have any pictures of the location and a description of what is needed to remove on the car to get at the bleed ?
I guess I will go ahead and install a remote bleeder.
I have a hard time believing that just fluid contamination caused a complete hydraulic failure and that it is not the master cylinder etc, any experience with this?
Thanks,
Tim
Old Oct 5, 2014 | 10:20 PM
truckplay's Avatar
truckplay
did you run the master cylinder dry ? you can use a vacuum pump to suck the air out through the reservoir, but I think you lost a slave
Old Oct 6, 2014 | 03:11 AM
Bill Dearborn's Avatar
Bill Dearborn
The best I can do is the attached file copied from the Service Manual. You can pretty much forget about installing the remote bleeder unless you drop the drive train.
Bill
File Type: pdf
Old Oct 6, 2014 | 07:51 AM
MARSC6's Avatar
MARSC6
Bill
I just did a clutch last week and don't see how you can even bleed it with the drive train in.
Old Oct 6, 2014 | 12:14 PM
jonathontodd's Avatar
jonathontodd
Default clutch
My clutch went to the floor last weekend...had to have it towed home. Changed the master cylinder and it has never felt better.
I'm was getting soft clutch pedal for about a year...I guess it eventually failed completely.
Clutch master is the cheapest/quickest part to change in that system.
Old Oct 6, 2014 | 02:36 PM
cclive's Avatar
cclive
Before removing the drivetrain to check the slave, I would throw a new master at it...comparatively very inexpensive part...and more likely the problem.
Old Oct 7, 2014 | 08:28 PM
Timz06's Avatar
Timz06
Guys thank for the info. I will go the master route, I think that is the issue, but I am still going to have to get the air out of the line I guess after a bench bleed?
How hard is it to pull the master?
Tim
Old Oct 7, 2014 | 08:38 PM
timd38's Avatar
timd38
I put a Tick master in. It is much better than the GM one.
http://www.tickperformance.com/tick-...rvette-c6-z06/
Old Oct 9, 2014 | 05:10 PM
Timz06's Avatar
Timz06
But not cheap either! I never had problems with the stock mc, except this (possible) failure.
Old Oct 21, 2014 | 07:42 PM
timmyZ06's Avatar
timmyZ06
sorry to highjack, but what you guys think is my problem, my zr1 clucth pedal is really harder than any other zr1. all of them are stock clutch mine included! I got the car at 6000 miles and the fluid never was changed it was almost pasta inside the reservoir!! is the master or the slave or both??? i really dont feel like taking apart the drive train!!!
To c6 (z06) clutch bleeding
