2008 Idle Speed
Old Oct 14, 2014 | 03:38 AM
gnguru's Avatar
gnguru
Default 2008 Idle Speed
My '08 automatic Vette idles at about 500 RPM stopped in gear. I think it needs to be sped up a pinch to maybe about 700-750 RPM. Can anyone tell me an easy way to do that? Everything in the engine compartment is covered up but I'm sure there's a simple screw adjustment somewhere to do this. Thanks
Old Oct 14, 2014 | 08:28 AM
dev1360's Avatar
dev1360
No adjustment. It is changed in the tune on the ECU.
If the car is stock, it is set where GM determined it needed to be. Just leave it alone.
Old Oct 14, 2014 | 10:16 AM
haljensen's Avatar
haljensen
My '08 A6 idles @ 550RPM in gear, has since new. No higher RPM needed.
Old Oct 14, 2014 | 10:47 AM
HOXXOH's Avatar
HOXXOH
Even though the tach may read somewhere in the 500-550 range, the readout from the ECU at the OBDII port is nearly 100 RPM higher.
Old Oct 14, 2014 | 11:43 AM
Speedforhire's Avatar
Speedforhire
LS3 A6 cars "Target Idle Speed" is set at 600rpm P/N and 575rpm in Gear at full operating temp..............and as HOXXOH said it will NOT be accurate at the dash gauge. You would need real time monitoring through the OBD port to get the most accurate reading.
Old Oct 14, 2014 | 01:45 PM
cclive's Avatar
cclive
No idle screws anymore...the computer is running things.
To 2008 Idle Speed
