Still chirping
Old Nov 2, 2014 | 04:17 PM
tennblkc6's Avatar
tennblkc6
go buy some panty hose and wrap and tie it around the crank pulley and the other pullies one at a time to see which one makes the noise.
Old Nov 4, 2014 | 03:23 PM
HBsurfer's Avatar
HBsurfer
Silence! Thanks to all of your input I isolated the noise to the alternator. It was still charging fine but something was failing internally. I am not sure if I could have located the exact problem inside the unit or not. I took the easy way out and replaced the alternator. Easy repair and the chirping is gone. Didn't want to leave the thread unresolved in case somebody down the road finds it during a search. Thanks again for all of the suggestions!
Old Nov 4, 2014 | 04:38 PM
tennblkc6's Avatar
tennblkc6
good to hear you got it sorted.
so...how did you find out it was the alternator?
Old Nov 4, 2014 | 05:03 PM
HBsurfer's Avatar
HBsurfer
I used an automotive stethoscope. $11 at Autozone. Touched it to all 3 idler pulleys, water pump, power steering and alternator. Hard to explain without hearing it through the stethoscope but there was no doubt that something was coming undone inside the alternator. I had never used a stethoscope before but it is a very cool thing to have in your toolbox. Installed a new AC Delco unit and the noise is gone.
Old Nov 4, 2014 | 09:17 PM
tennblkc6's Avatar
tennblkc6
I need to get one of those.
Old Nov 4, 2014 | 09:47 PM
VET4LES's Avatar
VET4LES
Good news. I've had a stethoscope for years and it sure comes in handy.
