need help...
Oct 30, 2014 | 08:20 PM
need help...
LG Header install on an 08 Z06.
Instructions say from the bottom, but she aint going...
Starter is out but its hitting between the k member and the firewall. Any suggestions???
Oct 30, 2014 | 10:04 PM
St. Jude Donor '14, '16
Make sure you have enough height to stand the header completely vertical to stab it in place, otherwise it just takes the right kind of shaking to get it in place.
Good luck!
Oct 30, 2014 | 10:25 PM
yep...get the car up higher so you can angle the header just right to get it in there...it'll go.
Oct 31, 2014 | 01:22 AM
the car is roughly 2' off the ground and the header isn't hitting the ground.
As I push the front end of the header flange up and over the k member the rear of the flange hits between the starter bump on the bell housing and the firewall.
I'll try taking a more vertical approach tomorrow or sat.
Nov 1, 2014 | 03:54 PM
no dice, car is well over 3' in the air and I can completely stand the header on end, and i'm still not making any headway...
Any other advice?
Nov 1, 2014 | 04:06 PM
Did you disconnect the dry sump lines?
Nov 1, 2014 | 07:44 PM
Talked to lg. you have to lower the cradle.
I pulled the cradle down about an inch and it slipped right in.
Great customer service by the way. 3pm on a Saturday and they answered on the 3rd ring.
Nov 1, 2014 | 07:51 PM
Quote:
Originally Posted by
SlowBusa08
Really fine people. I just started doing business with them and Anthony and his team are really focused on taking care of the customer.
