C6 oil change
Old Nov 2, 2014 | 10:09 AM
Bguilmino's Avatar
Bguilmino
6th Gear
Default C6 oil change
The computer on my C6 shows 30% left for an oil change. I have about 9,000 miles on this oil change already. That would be about 15,000 between oil changes. That seems like too much mileage, even using Mobil 1. I need some help with this.
Old Nov 2, 2014 | 10:52 AM
77vette05's Avatar
77vette05
I contacted GM about this same question. I was told the % life was very accurate. I was told by GM it calculates mileage, breaking, highway speeds, heat, cold ect..... When I first got my 05' I was getting about 13,000-15,000 mile oil changes. After the S/C install I'll be lucky if I get 10,000 out of it. That would show me the car does calculate different situations. I always change the oil once a year, no matter the mileage.
Old Nov 2, 2014 | 04:23 PM
carpe dm's Avatar
carpe dm
15K with the synthetics we have now, is not a problem for "normal" driving. I always change mine at least once a year, or around 10K, as I am on the conservative side.
Old Nov 2, 2014 | 04:55 PM
HOXXOH's Avatar
HOXXOH
Actually 30% remaining means you used 70% in 9,000 miles. 100% would be 12,857 miles, which is not an unreasonable number if a significant amount is highway use. My very first change came at 3% and 14,167 and I've never changed at less than 10,000.
Trust your DIC.
Old Nov 2, 2014 | 05:51 PM
Bguilmino's Avatar
Bguilmino
6th Gear
Thanks, I appreciate the info.
Old Nov 5, 2014 | 08:51 AM
oldtee's Avatar
oldtee
Not me.... I change my oil and filter at 5000 miles. True that .. that Mobil 1 is very good oil but a prime reason to change oil is to remove the contaminants that accumulate there in. I doubt Mobile 1 does much with the acid build up in oil.
I also open my filter and read the pleats.
It's your car but oil is cheap. Going 15k miles is bragging, not good engine management.
Old Nov 5, 2014 | 09:29 PM
CI GS's Avatar
CI GS
Originally Posted by HOXXOH
Trust your DIC.
I dunno. Somehow, that's never worked for me....
Old Nov 5, 2014 | 11:52 PM
jrose7004's Avatar
jrose7004
I do one year or 10000 miles. I never go 10000 miles in one year in my Vette so it's all about time with me. The manual says to go by your DIC.
Old Nov 6, 2014 | 12:27 PM
bluekey28's Avatar
bluekey28
No vehicle ever failed because of regular maintenance.
Old Nov 6, 2014 | 06:31 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
One year or DIC for me, whichever comes first.
Old Nov 6, 2014 | 06:44 PM
VET4LES's Avatar
VET4LES
I drive 3,000 miles a year and change the oil once a year per the manual.
Old Nov 8, 2014 | 07:03 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
I dont believe going the 15,000 miles will hurt your engine however I believe it would be safer to change it at 10,000 just for the peace of mind. At $35.00 per oil change it is inexpensive insurance. I change mine every year however unfortunately the car only gets driven about 4,000 miles per year. I know I have to drive it more.
Old Nov 8, 2014 | 01:02 PM
cclive's Avatar
cclive
If much of your driving is on the highway, then that oil life is normal. It's up to you if you want to use the info that it is giving you, but GM says the info is accurate.
Old Nov 10, 2014 | 01:01 PM
GOLD72's Avatar
GOLD72
Trust your DIC.
If my 07 LS2 was allowed to go over the once a year limit on oil changes, the OLM would prorate to over 12k miles to reach 0% life. My 2010 CTS Wagon would prorate to 10,600 miles but I change it every 10k because it is a convenient number. My 2011 ZR1 won't make 7k before it hits 0%.
Old Nov 10, 2014 | 04:23 PM
Sales@Texas-Speed's Avatar
Sales@Texas-Speed
Premium Supporting Vendor
True, but GM also said there wasn't a problem with LS7 heads..lol. On a serious note, it's probably fine to go until the says to change the oil, but it's just not worth the chance to me. I'd rather just change it at 5000 miles or so and know I'm not going to have future problems. I think you would have to send your oil off for analyses to really know how much life it has left and then change oil based on that.
Old Nov 11, 2014 | 12:47 PM
Seadawg's Avatar
Seadawg
Mobil 1 holds up very well in vettes Search for Blackstone Labs, and you will find all kind of oil analysis test results out here. I have no problem at all going 10k between changes now, based on my own oil analysis test results on my vette over the years.
Old Nov 11, 2014 | 12:50 PM
Seadawg's Avatar
Seadawg
AND, there has never been a veette mentioned out here that has had issues from oil not being changed frequently enough either. Ever!
To C6 oil change
Old Nov 12, 2014 | 05:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I've run my oil down as low as 30% life remaining, then did a change and sent a sample to Blackstone Labs. They said the oil was still ok and recommended I go longer for the next change.
So I think the OLI works well, at least on the C6.
But I have a hard time looking at all those miles and not changing it.
Old Nov 12, 2014 | 06:34 PM
Cherokee Nation's Avatar
Cherokee Nation
The last oil change was at 22% (DIC) with 4200 miles.I have never let it go over 5000..Just Me.
Old Nov 16, 2014 | 08:55 PM
dmoneychris's Avatar
dmoneychris
Default Signature Series
AMSOIL 0W-30 Signature Series & AMSOIL Ea Oil Filters
(For 'Severe' Service Up to 15,000 miles or one year, whichever comes first.)
Follow you're DIC or 15k or 1 year, whichever comes first. I have been very impressed w/this oil in my 2013 MN6 GS.
(https://www.amsoil.com/shop/by-produ...?code=AZOQT-EA)
(http://www.amsoil.com/newsstand/arti..._hsmi=14698385)
