transmission question
Old Nov 4, 2014 | 07:21 AM
4horseman's Avatar
4horseman
Default transmission question
will a 2007 corvette t56 fit in a 2005 Base???
will a c5zo6 tranny fit in a 2005 base
Old Nov 4, 2014 | 02:05 PM
4horseman's Avatar
4horseman
Anyone?
Old Nov 4, 2014 | 02:13 PM
needcheese's Avatar
needcheese
The transmission is the only thing being changed. The 2007 to 2005 will not fit the diff. There was a change from 05 to 06 because of the weak 05 diff. I have no idea on the c5
Old Nov 5, 2014 | 02:09 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
The 2007 will not fit unless you changed the extension housing to 97-05 unit.
The C5 Z06 transmission will be a direct bolt in.
You will need to modify the 2 reverse sensor connectors to make everything work.
__________________
To transmission question
