2008 c6, water leak
Old Nov 11, 2014 | 04:06 PM
BullittEV's Avatar
BullittEV
Veteran: Marine Corps
Default 2008 c6, water leak
Got a water leak on the passenger side right near the oil filter..
is this the water pump?
Just bought this used @ 54K - 2008 C6 LT3
Old Nov 11, 2014 | 05:15 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Are you sure it's a water leak from the engine?The A/C drain is in that area and if the car is not over heating ,that may be what it is.
Old Nov 11, 2014 | 06:08 PM
edcologne's Avatar
edcologne
my oil filter is on the drivers side...
definitely rule that out first, switch off heater/ac for a day or so and see if its gone.
remember, ac also automatically runs if the heater is directed all or partially towards the windshield (unless you actively switch it off).
Old Nov 11, 2014 | 06:24 PM
BullittEV's Avatar
BullittEV
thanks for the replies..
i meant parallel to the oil filter but on the passenger side is where the leak is coming from. I did have the heat running for a bit, and after inspecting the ground, it was water.. the water pump would leak coolant, correct?
Old Nov 11, 2014 | 06:31 PM
edcologne's Avatar
edcologne
yes.
(based on the assumption there is actually coolant in your system and not just water).
if its just water on the ground its probably condensed from the ac or maybe rain or wash water coming from another area.
how does it taste?
jk
Old Nov 11, 2014 | 06:41 PM
timd38's Avatar
timd38
yes.
how does it taste?
jk
It would also be slippery if it is coolant.
Old Nov 11, 2014 | 08:32 PM
HBsurfer's Avatar
HBsurfer
If it is clear water, I would think it is just a/c condensation. I can't think there is anywhere on the car that would have plain water except the windshield washer reservoir.
Old Nov 11, 2014 | 09:48 PM
cclive's Avatar
cclive
Info always helps...are you in a humid area?
To 2008 c6, water leak
