LS2 drysump question
Old Nov 13, 2014 | 12:13 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Default LS2 drysump question
WHen you convert the LS2 motor to a LS7-9 drysump system what do you do with the dipstick hole in the block?
Is there a freeze plug that will press into the hole in the block ? Or do I have to keep the tube and dipstick?
If there is a plug anyone know the size?
I'm at work and cant just go measure the hole
Old Nov 13, 2014 | 01:27 PM
el es tu's Avatar
el es tu
I dont think you can convert to the ls7 one because of the special crank thats used for the system. That said ARE and Aviaid make drysump systems for these cars. Aviaid sells one called the LSA which was something like 1800bucks iirc. Its also the only one Ive heard of that doesnt require removing the ac.
Ill see if I can pull up the link...
EDIT:
Wow the price jumped significantly since I last checked it out - $2800
http://www.xplosiveperformance.com/D...-A_p_3090.html
Originally Posted by Xplosive Performance
“A” Scavenge Only Pump Dry Sump System — Cylinder Head Mount
Designed for street use and mild competition. Uses OEM pump for pressure. Retains use of factory air conditioning and other accessories.
Includes:
Aviaid 2-section dry sump pump (scavenge only) with Gilmer drive gear
Bracket mounting pump to cylinder head
Oil pan (choice of 2)
Modified LS2 cast pan
ARE cast aluminum pan
Sump tanks (choice of 3)
OEM Corvette Z06 (optional internal baffle)
6" diameter round (8 or 10-quart system capacity)
9" diameter round (12 quart system capacity)
Sump tank vent, heater and sight tube (optional)
Serpentine/Gilmer drive pulley (replaces OEM serpentine idler pulley)All necessary lines and fittings (optional)
Features/Benefits:
Retains factory air conditioning
Eliminates oil starvation in hard cornering and high
RPM operation
Cooler operating temperatures
Larger lubrication system capacity
Eliminates parasitic horsepower loss through excessive windage
Provides more usable power
Old Nov 13, 2014 | 02:33 PM
AzMotorhead
Here's what was done.
LS2 block and heads
LS7 style crank(long snout)
LS7 Oil pump
LS7 Front cover
C6R timing chain
LS7 Oil pan
Now how do you block off the dipstick tube???
Old Nov 13, 2014 | 02:36 PM
el es tu's Avatar
el es tu
Found this:
Originally Posted by PUMBA
You will need to remove your oil dip stick housing, tap the hole, and install a pipe plug. You will check you oil level on your dry sump tank. The dip stick would be a leak as the dry sump scavenge pump tries to create a vacuum in your oil pan.
Talk you your dry-sump system supplier and see if there are other preparation items that they recommend.
Good luck.
http://ls1tech.com/forums/newreply.p...ply&p=16301124
Old Nov 13, 2014 | 02:51 PM
timd38's Avatar
timd38
Memory is bad, but I think a 9/16" tap is what you need.
Old Nov 14, 2014 | 09:44 AM
timd38's Avatar
timd38
Has anyone installed one of these systems?
He did say the the instructions were universal in the email, but the instructions don't match the parts that are shown.........
Old Nov 18, 2014 | 09:56 PM
KENS80V's Avatar
KENS80V
My LSA block was converted to a dry sump. ERL installed a frost plug in the dipstick hole.
The benefit to using a frost plug is the fact you can always punch it out and re use a dip stick if the block is ever converted back to wet sump in the future.
Old Nov 19, 2014 | 08:37 PM
KENS80V's Avatar
KENS80V
I just measured my dipstick tube hole in the block. A 3/8" drill bit fit perfectly in the hole. I'd say it would be a safe bet that it's a 3/8" frost plug. There are no other sizes that are even close. Keep in mind that this is a LSA block. It's similar to other LS blocks. The main differences are the piston oil squirters.
Just a heads up. There is no such thing as a 9/16" pipe tap. Even if there was it's way too big. The hole is 3/8" so a 1/4" pipe tap would be the appropriate size. The hole would need to be drilled out with a 7/16" drill bit. Please keep in mind that these measurements were taken from a LSA block.
Old Nov 19, 2014 | 09:05 PM
KENS80V's Avatar
KENS80V
I found a vendor selling it. The GM part number is #12557520
http://www.improvedracing.com/oiling...720-p-316.html
To LS2 drysump question
